audio hand off/streaming software
great, but does them music exist on like account(spotify server) or is it on my phone/computer
spotify server... that's what any streaming service will do... that's what streaming is
right i kinda meant like just music from my phone like sonos but thats my miscommunication, so got any that will do the sonos styley thing
...what?
i was looking for something that just tells my computer what to play or something that sends the songs over the wifi to the computer
Controller or streaming? In other words, where are the files? If it's on PC, then what you're looking for is a controller. If it's on the phone then what you're looking is a streamer.
For streamer, for IOS there's AirDisplay that works through WiFi. Streams video, games, and audio, but bad audio.
For good audio, use bluetooth dongle or built-in PC bluetooth adapter instead, and use it as A2DP device.
clearly said android and the files are on both i just don't have a preference
If we're being dicks to each other, clearly you haven't googled. Results 2 and 5.
I've used airplayit a bunch of times its a master slave type of system where one device is the master sending audio and the slave device receives and basically becomes a remote speaker
good for music and podcasts but bad for something with a video component as there is a delay
