So I'm currently Overclocking my GPU (Pretty sure I won the lottery)... I'm wondering if there is any use of overclocking the Memory clock, to get a bit higher clock speed (Almost rounding up to 1600)
MSI GTX 980 Gaming
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/269022-more-important-clock-speed/
MSI GTX 980 Gaming
Not really. memory overclocking does in theory boost FPS, but not by much at all. your biggest gains will be made by GPU clock speed boosts
CPU: AMD FX8350 @4.4GHz | MOBO: ASUS Sabertooth 990FX R2.0, 990FX chipset | RAM: 16GB (4x4) dual channel Patriot Xtreme series DDR3 @1866MHz @1.65V | GPU: Asus Radeon R9 Fury Strix| PSU: Corsair AX860i 860 watt | CPU cooling: Noctua NH-D15S + additional Noctua NF-F12 | Case:Corsair C70 Black | Storage: 3x 128GB Samsung 840 pro SSDs; 1 for the OS, 2 in RAID 0 for games. 3x WD Red 3TB HDDs in raid 5 for bulk storage | Displays: 1x Dell 3007WFP 30 inch 2560x1600 IPS LCD. 1x I-Inc IH253DPB 25 inch 1920x1080 TN LCD | Keyboard: Corsair K70 with Cherry MX brown switches + Blue LED backlight | Headphones: Sennheiser HD 280 Pro | Mouse: Logitech G600 @1100 DPI | OS: Win 10 Pro 64 bit |
Mfg/model number: Clevo/W355SSQ | CPU: Intel i7 4710MQ @3.5GHz  | MOBO: W35xSS_370SS, HM87 Chipset | RAM: 16GB (2x8) dual channel Crucial Ballistix DDR3 @1866MHz | GPU: GTX860m 2GB Gddr5 | Battery: 76,960mW/h 8 Cell battery, 3 Hrs full on a full charge | Storage: 1x 128GB Samsung 840 pro SSD for the OS. 1x WD Red 1TB HDD For storage and games | Displays: 1x 15.6" 1080p LCD | Keyboard: Full 103 key back-lit keyboard | Mouse: Logitech M510 | OS: Win 10 Pro 64 bit |
Well, the GTX 980 is a bit memory bandwidth constrained. It wouldn't hurt to up it a little bit and test the performance.
But clock speed still matters more. See this article:
http://www.anandtech.com/show/8526/nvidia-geforce-gtx-980-review/22
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
Go after a good stable core clock, then OC the memory; memory OC is not that performance-increasing, but does indeed boost it.
Some people found that they cards would hit like 1550 core clock, 7.5GHZ memory clock; but that if they  decreased the core to something like 1530mhz, then they could go up to 8 GHz on the memory, having better final FPS.
So, go play around with the settings and the results, I'm sure you will have fun.
