I'd like to buy a new graphics card but I'm torn between two designs.
The Nvidia GTX 750 Ti
And
The AMD R9 270
I don't care about a lot of things. I want the best price to performance.
CPU: FX 6300 AMD
PSU: 500W
Motherboard: Gigabyte GA-78-LMTS2P
GPU: AMD HD Radeon 7750 (Blurgh)
Monitors: 24" 1680x1050 + 17" 1280x1024
I'm also a linux gamer. If that makes any difference.
https://linustechtips.com/topic/268930-new-graphics-card-help/
For the best PPP get the 270.  Plus you get the free games for extra value.
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
https://linustechtips.com/topic/268930-new-graphics-card-help/#findComment-3651807
And
The AMD R9 270
CPU: FX 6300 AMD
PSU: 500W
The 270 will stomp all over the 750ti. Whats your budget btw?
CPU: AMD FX8350 @4.4GHz | MOBO: ASUS Sabertooth 990FX R2.0, 990FX chipset | RAM: 16GB (4x4) dual channel Patriot Xtreme series DDR3 @1866MHz @1.65V | GPU: Asus Radeon R9 Fury Strix| PSU: Corsair AX860i 860 watt | CPU cooling: Noctua NH-D15S + additional Noctua NF-F12 | Case:Corsair C70 Black | Storage: 3x 128GB Samsung 840 pro SSDs; 1 for the OS, 2 in RAID 0 for games. 3x WD Red 3TB HDDs in raid 5 for bulk storage | Displays: 1x Dell 3007WFP 30 inch 2560x1600 IPS LCD. 1x I-Inc IH253DPB 25 inch 1920x1080 TN LCD | Keyboard: Corsair K70 with Cherry MX brown switches + Blue LED backlight | Headphones: Sennheiser HD 280 Pro | Mouse: Logitech G600 @1100 DPI | OS: Win 10 Pro 64 bit |
Mfg/model number: Clevo/W355SSQ | CPU: Intel i7 4710MQ @3.5GHz  | MOBO: W35xSS_370SS, HM87 Chipset | RAM: 16GB (2x8) dual channel Crucial Ballistix DDR3 @1866MHz | GPU: GTX860m 2GB Gddr5 | Battery: 76,960mW/h 8 Cell battery, 3 Hrs full on a full charge | Storage: 1x 128GB Samsung 840 pro SSD for the OS. 1x WD Red 1TB HDD For storage and games | Displays: 1x 15.6" 1080p LCD | Keyboard: Full 103 key back-lit keyboard | Mouse: Logitech M510 | OS: Win 10 Pro 64 bit |
https://linustechtips.com/topic/268930-new-graphics-card-help/#findComment-3651808
750ti is better!
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/268930-new-graphics-card-help/#findComment-3651817
You guys gotta read more than the first few lines he's on Linux, better OpenGL support from Nvidia GPU's = better performance over the 270.
https://linustechtips.com/topic/268930-new-graphics-card-help/#findComment-3651818
If you don't mind putting just a bit more, you could get this:
http://www.amazon.co.uk/MSI-Nvidia-TF-PCI-E-Graphics/dp/B00DIH8OW8
(since you apparently are from UK)
Unless you don't have sufficient power supply.
In which case you could get this:
http://www.amazon.co.uk/Nvidia-GeForce-Graphics-GDDR5-PCI-Express/dp/B00ICUGOP0
https://linustechtips.com/topic/268930-new-graphics-card-help/#findComment-3651863
Is it okay? I mentioned I had a 500W. It's a good card but I'm worried it might be a bit overkill. An extra £30 might be worth spending but I don't know.
https://linustechtips.com/topic/268930-new-graphics-card-help/#findComment-3651877
Oh sorry, didn't notice you wrote the power supply there as well.
500W should be able to handle that just as well.
FX-6300 + GTX 760 + all that extra won't take more than 400W.
But as you said, it might be overkill.
Check the other one I added later.
https://linustechtips.com/topic/268930-new-graphics-card-help/#findComment-3651886
And
The AMD R9 270
CPU: FX 6300 AMD
PSU: 500W
The R9 270x stomps the 750Ti. Or you could go for the GTX 760 like @sapphirethunder said. Though the difference in fps is increased about 2-3fps more.
https://linustechtips.com/topic/268930-new-graphics-card-help/#findComment-3651900
Apparently a 500W ought to handle it Okay. But is it good for price to performance?
GTX 760 is the one of the best. Especially for that price seen there.
And the Asus/Msi models are the one with coolest operating temperatures.
Even with the original listed price, it is still one of the best choices.
https://linustechtips.com/topic/268930-new-graphics-card-help/#findComment-3651911
Here, it has the same specs as you. Might help you decide.
https://linustechtips.com/topic/268930-new-graphics-card-help/#findComment-3651921
