After awhile of doing research and thinking I have finally decided to attempt to make my computer custom water cooled! These are the parts so far. any feedback would be absolutely amazing. My budget is around 200usd (willing to go over slightly) so if you guys have any recommendations I'm all ears! (ohh the case I use is nzxt h440 which I don't know if it has room for a conventional reservoir)
~KuriousCat
http://www.amazon.com/dp/B0067LW8RY/ref=wl_it_dp_o_pC_S...
http://www.amazon.com/dp/B00FQQV3A4/ref=wl_it_dp_o_pC_n...
http://www.amazon.com/dp/B00L5IXKYE/ref=wl_it_dp_o_pC_S...
http://www.amazon.com/dp/B0060861IG/ref=wl_it_dp_o_pC_n...
http://www.amazon.com/dp/B00F6S0XJO/ref=wl_it_dp_o_pC_n...
http://www.amazon.com/dp/B00LKNV596/ref=wl_it_dp_o_pC_n...
Pump/reservoir:http://www.amazon.com/dp/B00A42X2KY/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=1HIZS5XLQD3IZ&coliid=IS1GGPECIPOZA
https://linustechtips.com/topic/267432-help/
Changing the title to something more relevant would be helpful :P
CPU: 5820K GPU: Gigabyte G1 970 RAM: 16 GB Crucial Ballistix Mobo: EVGA m-ATX Cooler: Corsair H100i Case: Xigmatek Aquila PSU: NZXT 700W Monitors: 2 x Wasabi Mango (1440p)
Do you play Go/Baduk/Weiqi? I am AGA 4D.
"We do not shop by brand, we shop by what delivers us the best performance, features and quality for the money we're spending" - Linus (Techquickie)
https://linustechtips.com/topic/267432-help/#findComment-3632125
it seem you got most of the cooling parts
but you forget a pump
are you just cooling the CPU or you want to cool the GPU too?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/267432-help/#findComment-3632129
Thanks Dragoon just added the pump/res
Just cpu for now
while i am no expert in watercooling parts
i think you will be good with the parts you listed
just need to install them will be the tricky part
https://linustechtips.com/topic/267432-help/#findComment-3632166
