Foobar help needed!
By
-TesseracT-
in Troubleshooting
in Troubleshooting
Solved by Volbet,
Hmm, do you have any other FLAC songs in your library? You might just have enabled a filter by accident.
You can also try to upgrade Foobar to the latest version (1.3.6). It might just be that the installation screwed up.
kerriya ·
Posted in Cases and Mods4 -
octester ·
Posted in Troubleshooting5 -
DavidPatrascu ·
Posted in General Discussion7 -
2
3
bill well ·
Posted in Peripherals1 -
4
2
play_circle_filled
Latest From ShortCircuit:
