Just got it today. Worked fine for about 6 hours. I hit the gamer profile button on my GPU tweak software and the screen goes black with "out of range" message. I jumped on my old monitor to revert the over clock and still nothing. On reboot I can get the swift to display the bios so I reset all my over clocks to normal. It shows the windows logo then just black again with the same message. I can't get it to display the desktop at all. Anyone have any ideas what could be causing this?
i7 4770k/Maximus VII Hero/Titan X/ 500gb 850evox2 r0/1000 EVGA G2
https://linustechtips.com/topic/267403-rog-swift-i-need-help/
are you able to reset your GPU OC?
if not see if you can boot to safe mode
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/267403-rog-swift-i-need-help/#findComment-3631753
Oh dear .. this is a known issue .. a lot of ROG Swift owners have issues with the monitor like no signal & blurry screens .. you need to RMA
Thats why I got the LG 34UM95 instead of the Swift .. read the reviews on newegg and amazon .. lots of people are complaining
"If Everton were playing at the bottom of the garden, I'd pull the curtains." - Bill Shankly
https://linustechtips.com/topic/267403-rog-swift-i-need-help/#findComment-3631754
Oh dear .. this is a known issue .. a lot of ROG Swift owners have issues with the monitor going from no signal to blurry screen .. you need to RMA
Noo don't tell me that :( tell me some quick fix that will make it work instead
https://linustechtips.com/topic/267403-rog-swift-i-need-help/#findComment-3631788
Yea I saw that earlier. And I just completely reinstalled my Nvidia drivers and now it won't even load the bios screen
https://linustechtips.com/topic/267403-rog-swift-i-need-help/#findComment-3631827
Okay try using a different monitor with the same DP cable, if everything works this means the monitor must be returned
https://linustechtips.com/topic/267403-rog-swift-i-need-help/#findComment-3631830
I actually have a 34um95 as well it works just fine. Looks like I'm RMA ing. :( what a pain. I just sold my other 144hz monitor too
https://linustechtips.com/topic/267403-rog-swift-i-need-help/#findComment-3631837
Im really sorry to hear that buddy .. as I said I did my research before buying a 1440p monitor, I really wanted the ROG Swift but was disappointed when I read all the issues that are going around. The funny thing is Acer 1080p G-Sync monitor have no such issues at all ..
https://linustechtips.com/topic/267403-rog-swift-i-need-help/#findComment-3631844
Im really sorry to hear that buddy .. as I said I did my research before buying a 1440p monitor, I really wanted the ROG Swift and I was disappointed when I read all the issues that are going around. The funny thing is Acer 1080p G-Sync monitor have no such issues at all ..
I shoulda waited for their wqhd gsync. Asus customer service is horrid :( not looking forward to this process
https://linustechtips.com/topic/267403-rog-swift-i-need-help/#findComment-3631852
So it started working again...I installed some software from the Asus website called multiframe which seems like it has nothing to do with it...I wonder if I try to oc my GPU again if it will break it
https://linustechtips.com/topic/267403-rog-swift-i-need-help/#findComment-3631946
