hey Linus community
My internet was just turned off and disconnected. I turned it back on and reconnected but it won't connect to the Internet. The wireless and wan lights are flashing but not the Internet symbol?
Can someone plz help
If your wondering how I posted this I'm on a phone with 4g
Thanks
Wolffangs147
Its when dragons have so much sex that the cpu cant handle it
https://linustechtips.com/topic/267294-internet-problems/
Check to see if your phones are working? maybe your phone line is down.. if it isnt that you may have just lost connection with your ISP should be up in 30 mins - 2 hours... happens once or twice a month for me :(
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/267294-internet-problems/#findComment-3630374
I don't have a landline/home phone. My family only uses mobile phones
https://linustechtips.com/topic/267294-internet-problems/#findComment-3630384
