the D5 is a great pump.
the pump top is what you are looking for and specifically one to attach the reservoir to.
bitspower
top
reservoir kit
koolance
top
reservoir and top
prolly like this:
these are koolance D5 tops with 200mm reservoir tubes and instead of 60mm diameter
these are 80mm in diameter.
airdeano
https://linustechtips.com/topic/26656-new-to-water-cooling/#findComment-338921
bitspower
top
reservoir kit
koolance
top
reservoir and top
prolly like this:
airdeano
thx. may i know what case is in the picture?
https://linustechtips.com/topic/26656-new-to-water-cooling/#findComment-339227
I believe this is a Caselabs SM8
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/26656-new-to-water-cooling/#findComment-339235
