If a conputer fan gets to much voltage. What will happen?
It will spin faster and faster until the circuitry blows. Once that happens it will smoke and stop spinning, and if you are lucky you might even get some sparks.
https://linustechtips.com/topic/266523-fan-voltage/#findComment-3620911
It will spin excessively fast before it probably burns out.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/266523-fan-voltage/#findComment-3620916
Hey look! It's The Fourth of July in my computer.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/266523-fan-voltage/#findComment-3620936
What fan brand do you have @phillrulz?
That was just a generic brand fan, managed to make it float from its own downforce, wouldnt recommend it for normal use.
5820k@3.8GHz| Corsair H100i |Gigabyte x99 SLI | Corsair 16GB | EVGA 780Ti SC ACX SLI x2 |240GB SSD120GB SSD 512GB SSD 2TB HDD | 3x ASUS VN247H 24" ( nVidia Surround)
https://linustechtips.com/topic/266523-fan-voltage/#findComment-3620991
Noctua or Fractal Design?
Most premium/not cheap fans can take 13-14v safely, but its mostly the cheap fans that can take a bunch of voltage. I have a Logisys fan that can take 30v before blowing(not for long though), but its a pretty crappy fan other than that. Unless if you are wanting to screw around(and possibly wreck a fan), I would avoid over volting a fan. If you need more airflow, just get a Delta fan.
https://linustechtips.com/topic/266523-fan-voltage/#findComment-3621130
Eeh. This is a little stange. I want to build a biolite myself. I want small 4000rpm fans. I foud the fd r2 40mm fans where cheap and awesome. But the generators delivers 12v-15v and the fan is a 9v fan. Should be ok. Just had to check
Think it would be okay?
Fractal Design R2 40mm Silent runs with 9v. If i give them 12v-15v would anythig happen then?
NEEVS
https://linustechtips.com/topic/266523-fan-voltage/#findComment-3621192
