they normally do, or if not, they have lots of clearances
CPU Intel I7-4700MQ @2.4 ghz, turbos to 3.4
Motherboard  whatever toshiba put in the thing
RAM 8GB 1600mhz
GPU  Nvidia Geforce GT 740M
Storage 750Gb 5400rpm
Cooling  Crappy laptop fan
Operating System  windows 8 64 bit
01101001 01100110 00100000 01111001 01101111 01110101 00100000 01101000 01100001 01100100 00100000 01110100 01101111 00100000 01000111 01101111 01101111 01100111 01101100 01100101 00100000 01110100 01101000 01101001 01110011 00100000 01101001 00100000 01100100 01101111 01101110 00100111 01110100 00100000 01100010 01101100 01100001 01101101 01100101 00100000 01111001 01101111 01110101
https://linustechtips.com/topic/266146-pc-case-gear-australian/#findComment-3615841
my mum (with a U because im australian) told me i need to order my christmas presents soon but i was wondering if PC case gear normally have christmas sales and if so when do they start
thanks
They do have sales every now and then, but I don't believe that they have any specific Christmas sales. I'm on that site a lot and have never seen any particular special Christmas sales.
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/266146-pc-case-gear-australian/#findComment-3615845
I check their clearances page every few days...
Make a habit out of it and you won't need to worry about sales, cos your always checking them for updates anyway.
Love PCCG, I'm in Radelaide, and have never had an issue with PCCG and their items arriving.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/266146-pc-case-gear-australian/#findComment-3615927
what are planning on getting? Just curious. :)
@ULTIMATE209
https://linustechtips.com/topic/266146-pc-case-gear-australian/#findComment-3615929
I love PCCG too. I've bought a couple of things from them and they always arrive pretty quickly from Melbourne to Sydney. They're very efficient B). I've talked to one of their staff several times and he's quite helpful, patient and nice. You can't get better customer service then that. :)
https://linustechtips.com/topic/266146-pc-case-gear-australian/#findComment-3615949
yeah unfortunately a lot of themain australian computer shops (ple, msy etc...) that offer decent prices can't afford to cut on sales.
"The best solution to a problem is usually the easiest one" - GLaDOS 2011
Specs here if needed: http://au.pcpartpicker.com/p/HVf6f7
Thanks, bai!
https://linustechtips.com/topic/266146-pc-case-gear-australian/#findComment-3616095
