Hello! I'm building a Gaming PC. Which GTX should I get (I will SLI)?
If needed, here is how I will rank them:
1. Zotac GTX 980 AMP! Extreme Edition
2. EVGA GTX 980 Classified ACX 2.0
3. MSI GTX 980 Twin Frozr V
4. Gigabyte GTX 980 G1 Gaming
5. Asus GTX 980 Strix
Thanks in advance!
https://linustechtips.com/topic/266124-gtx-980-help/
budget? where will you buy the components? post the whole build and maybe we can help you further. I'm from the Philippines btw :)
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615565
@AkoSiAllen None of these. Get reference cards for sli. They will be the cheapest and they will be cooler. If you get non blower style cards one will be shooting hot air up into the case and the other gpu causing it to heat up dramatically more. Reference cards blow all the heat directly outside the case.
Edited by SeanBond
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615572
If you want thermal throttling then ya get reference blower cooling LOL.
With respect, you have no idea what you're talking about.
Blower style cards, like SeanBond explained, are FAR better for confined spaces.
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615602
@iAsuno I got i7-5960x, RoG R5E, G.skill 16gb.
Heck! An i7 5960X! Those things aren't cheap. :o
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615633
It's called science ... More cooling surface area/Radiator and fans = better cooling. This is not up for debate.
and where does the hot air go? that's right, to the next card and inside the case.
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615638
Please stop. I have a reference 780ti. It's a much hotter card and I don't even get close to thermal throttling. Please stop talking.
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615640
Airflow thermals are also science. One that you appear to have missed the memo on. You are embarrasing yourself.
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615659
Good for your GPU LOL.
Ya more airflow and radiator surface area and fans means better cooling ... how hard is this to understand ?
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615664
Come on guys! Do you really need to start a flame war over this? I think not. Please try to just help out the OP. :)
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615668
is this pc just for gaming? this waaaaay too expensive especially here in the Philippines. you sure you don't want to spend your money on something else and get a cheaper PC?
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615708
How is it hard to understand the blowing all that hot air into the case will only give the card more hot air to use when it continues cooling the card. Do you think the heat magically goes away once it leaves the cards? lol Reference cards take the heat and remove it from the case.
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615713
I'm trying to explain this as simply as I can.
Reference card = Good cooler that puts all of the hot air outside the case
Non-reference = Better cooler that puts all of the heat INSIDE the case.
Lower air temperatures = MASSIVELY better for cooling.
Therefore putting two non-reference cards RIGHT next to each other is going to put them in a situation where it is harder to get air and the air that they DO get is warmer than it should be. And the reference cards will fare better.
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615716
So I decided to order EVGA GTX 980 Classified ACX 2.0 as most of you recommended. Thanks all!
two people recommended that. lol. Running those in sli is going to be a lot hotter and more expensive than reference. If you were just using 1 card evga all the way.
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615718
At the cost of extra internal GPU temps for all components on the GPU. There is a reason for aftermarket open air cooler ... hint it's because they cooler all components on the GPU in a superior fashion.
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615737
Sigh...the GPU temps WOULD be better because the air cooling them would be cooler to start with. Reference coolers are actually quite good to start with, especially with maxwell.
https://linustechtips.com/topic/266124-gtx-980-help/#findComment-3615750
