Problem with my gpu
Go to solution Solved by SkilledRebuilds,
Driver bug, or did you crash anytime recently...some random driver resets can screw with this stuff.
Uninstall GPU drivers and redo them.
/I had this on my AMD card, declocked profile, PC crashed, I booted with the profile still on (it shouldn't)
So i recently bought a msi gtx 970, about two months ago, and everything was working fine. But now my core clock is at 406 mhz and my mem is at 810 mhz as you can see in the screenshot. Video games are "working", but the frame rate is terrible. Anyone know what the problem is? Help would be much appreciated.
post-167053-0-23420700-1417970891_thumb.
https://linustechtips.com/topic/265628-problem-with-my-gpu/
Maybe the card is thermal throttling. What are the temps?
CPU: Ryzen 3700X VGA: RX 5700 8G RAM: 32GB 3200MT/s DDR4 Motherboard: B450 Aorus Pro
Storage: 2x1TB Crucial P2, 1TB Crucial MX500, 36TB NAS Cooling: Custom Loop 360mm & 280mm
PSU: Super Flower Golden Green HX 650W Case: Phanteks Enthoo Luxe
https://linustechtips.com/topic/265628-problem-with-my-gpu/#findComment-3609903
Why is your core voltage at minimum with no value?
Is it on auto or something?
https://linustechtips.com/topic/265628-problem-with-my-gpu/#findComment-3609907
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/265628-problem-with-my-gpu/#findComment-3609922
yea, it is '^^. Is that bad?
Try setting it at a constant 1.2v or something around there and see what happens...
https://linustechtips.com/topic/265628-problem-with-my-gpu/#findComment-3609940
Now that you mention it, it happened about two weeks ago. i'll try that ty.
https://linustechtips.com/topic/265628-problem-with-my-gpu/#findComment-3609944
Hope it's this, as its an easy fix:)
I'd do this before any voltage changes or anything like that...
https://linustechtips.com/topic/265628-problem-with-my-gpu/#findComment-3609960
