So I'm getting the list and materials together for this buld but i need some opinions and suggestions on this! Especially for the motherboard selection as well as RAM!
http://pcpartpicker.com/user/ilya2006/saved/X7f2FT
There's the list for all the parts!
Thanks!
CPU: i7 8700K (Cooled by Custom Loop)  GPU: Gigabyte G1 Gaming GTX 1080  RAM: 8GBx2 HyperX Fury  MOBO: Asus ROG Strix Z370-E PSU: EVGA 750W 80+ Gold Case: Thermaltake The Tower 900Storage: OCZ ARC 100 240GB SSD & Crucial BX100 500GB & 1TB WD Blue HDD & 2TB Seagate Barracuda Mouse: Mionix Castor   Keyboard: Ducky One  Display: Dell P2414H & Dell S2716DG
https://linustechtips.com/topic/265382-building-first-gaming-pc/
1) don't get AS5, use MX-4 or NT-H1 instead
2) I would look for a different SSD if I were you, the 730 series has slow write speeds on the 240GB model, and the 480GB doesnt fit into that budget for sure
3) dont get that motherboard and wifi adapter. But a motherboard that already has built in wireless, it will perform much better. I know ASUS has a couple Z97 boards with built in a/c
4) buy an EVGA G2 PSU instead
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3607403
I agree!
MOBO with WiFi: http://pcpartpicker.com/part/asus-motherboard-z97prowifiac
Better PSU: http://pcpartpicker.com/part/evga-power-supply-220g20750xr
Pretty good SSD for the price: http://pcpartpicker.com/part/crucial-internal-hard-drive-ct256mx100ssd1
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3607431
Thanks guys! I updated the list accordingly, also any suggestions for a hard drive?
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3607489
I would grab a WD Blue drive and adjust the capacity accordingly, it's doesn't perform as high as the black drive but you won't really see much difference. They're cheaper than the black.
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3607502
i second this
OP the build looks great BTW :) nothing else I would change
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3607523
This is much Better
4690k is mmore than good enough for gaming
Termal paste isn't needed.
CPU Cooler is cheaper and just as good.
Mobo supports 2-way SLI for in the future
Gaming only need 8GB of RAM
SSD is fast and good.
Lots of HDD space
Good GPU - more than enough for 1080p
Expensive case, but my friend has one and it is possibly the most beautiful case on Earth ( :P), with its glorious and giant side window.
Cheap but good enough PSU
Good monitor
Great network adapter
Same fan controller
Cheaper keyboard
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($217.98 @ Amazon)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($102.74 @ Amazon)
Motherboard: ASRock Z97 Extreme3 ATX LGA1150 Motherboard  ($104.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($59.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($114.00 @ B&H)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive  ($69.98 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($354.98 @ SuperBiiz)
Case: Corsair 760T Black ATX Full Tower Case  ($159.99 @ Micro Center)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($48.99 @ NCIX US)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer  ($12.99 @ Amazon)
Operating System: Microsoft Windows 8.1 Pro (OEM) (64-bit)  ($128.98 @ OutletPC)
Monitor: Acer GN246HL 144Hz 24.0" Monitor  ($242.98 @ SuperBiiz)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($32.99 @ Amazon)
Fan Controller: NZXT Sentry 2 Fan Controller  ($24.99 @ Newegg)
Keyboard: Razer Blackwidow Tournament Edition Wired Gaming Keyboard  ($59.95 @ Newegg)
Total: $1736.52
Generated by PCPartPicker 2014-12-07 02:50 EST-0500
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3607532
i second this
Thanks!
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3607642
If you are just gaming get a 4690K and 8GB of Ram insted of 16GB. May want to keep the ram if you think that is a good deal
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3607728
Thanks!
http://pcpartpicker.com/p/zv83dC
Here you go. This is the best looking and performing build I made.
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3607794
Extra thermal paste is not needed
H100i is just as good and cheaper
That motherboard is insanlely expensive - get a cheaper Z97 one.
RAM is too much money - get a cheaper RAM, 8GB is more than enough for gaming. Also, CORSAIR, even though they make great products, are quite expensive and cheaper RAM brands can be found, eg G.SKILL.
Change SSD to EVO - better quality
Great case choice - however is he wants to show off I would get the 760T as it is just spectacular.
RM PSU is not wildley popular and is not very reliable and is also expensive.
Why do you need a $54 optical drive? Who even had CDs or DVDs anymore? :P
You can save $10 on the monitor by going with the ACER equivilent
The keyboard is $100. WHY THE F*** do you need a $100 keyboard?!?!?!?! :P:D Just get a $50 Razer
A bit off topic, but what do you guys think of the INWIN S-FRAME?
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3607957
the INWIN S-FRAME is basically a work of art  :D
Do these coolers come with thermal paste? optical drive for my sake >.<
BUT THE KEYBOARD MATCHES MY MOUSE  :D I'm a big fan of SteelSeries as well
oh and just for the record I would like to go for a black and blue color scheme if possible haha
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3609943
Gaming is a big part but I'm also using it for other things as well, plus the 4790K was on sale at Micro Center :lol: . Also I have 16GB of RAM on my laptop so I feel thats a good place for it to be at.
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3609976
With the optical drive that blu ray drive has 3d blu ray funtionality
https://linustechtips.com/topic/265382-building-first-gaming-pc/#findComment-3623898
