I have an issue that when I turn on my computer,the fans will go up and down drastically in rpm speed and I let it on for a while but I was scared so I went to restart it wif the reset button
It will show my ram that it has 2gb but I have 4gb
It will then load and ntn happens from then
Please help asap
“It would seem that Our Lord finds our desires not too strong, but too weak. We are half-hearted creatures, fooling about with drink and sex and ambition when infinite joy is offered us, like an ignorant child who wants to go on making mud pies in a slum because he cannot imagine what is meant by the offer of a holiday at the sea. We are far too easily pleased.”
―  C.S. Lewis  :)
https://linustechtips.com/topic/264457-help-guys-please/
I waited for 7 secs and I went to reset
It is black screen when that happens
―  C.S. Lewis  :)
https://linustechtips.com/topic/264457-help-guys-please/#findComment-3596927
I also cleared CMOS twice
―  C.S. Lewis  :)
https://linustechtips.com/topic/264457-help-guys-please/#findComment-3596928
In detail,
First two is very fast
The rest is all the way up to normal
And dipping over and over again
My monitors receive absolutely 0 signal
―  C.S. Lewis  :)
https://linustechtips.com/topic/264457-help-guys-please/#findComment-3596946
Sry I did not clear CMOS
Wad I meant is I discharged the comp I left it unplugged and left it to discharge
I haven't yet clear the CMOS bcos I can't ATM
Is there a way to not clear CMOS yet fix dis?
:1
―  C.S. Lewis  :)
https://linustechtips.com/topic/264457-help-guys-please/#findComment-3597046
Try to reset with Jumpers on the mobo.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/264457-help-guys-please/#findComment-3597062
It's like 5 am here
I would want to do it in the day where I won't disturb anyone
It won't be a problem as long as I leave the PC discharged right?
―  C.S. Lewis  :)
https://linustechtips.com/topic/264457-help-guys-please/#findComment-3597117
It's like 5 am here
Yeah! Just power off! do the reset in day time as you said.
https://linustechtips.com/topic/264457-help-guys-please/#findComment-3597182
Thanks I can finally sleep ;-;
Hope it works
But I won't be sad of much if it doesn't
Its a friggin old comp
Gtx 430
-_-'
―  C.S. Lewis  :)
https://linustechtips.com/topic/264457-help-guys-please/#findComment-3597252
Anyways I cleared my CMOS
It was a coin cell battery
I did both resetting jumpers and CMOS
Anyways
What happened is that I went to on the computer but I forgot to put back my GPU as it was blocking the CMOS
I turned it off and I put the GPU back,when on it
No signal? :(
―  C.S. Lewis  :)
https://linustechtips.com/topic/264457-help-guys-please/#findComment-3600353
Nvm it's working fine now wif the GPU
Thanks for those who bothered to help ^,^
―  C.S. Lewis  :)
https://linustechtips.com/topic/264457-help-guys-please/#findComment-3600405
