Hey guys, I wondering if there are any nice external fan controllers out there. I don't mean ones that go at the front of your case. I'm looking for something that looks more like the high end usb headphone amps that sit on your desk. Probably 4x2x1 inches in size with 3-4 channels.
I use 6 27 inch monitors so getting up and going to the front of my case is a real pain. So I just want the fan controller to sit between the bases of 2 of my monitors. I've looked everywhere for something like this and haven't found anything that's even close...
I run a machining company that could easily design something like this if they simply don't exist. If that's the case I'd love to get some feedback on what else could be incorporated into the design.
https://linustechtips.com/topic/264075-external-fan-controller/
Something like this is very nice:
http://www.overclockersonline.net/?p=50084721
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/264075-external-fan-controller/#findComment-3591695
I think you may be out of luck. The only external fan controller I found was a device that you had to run your fan cable to, and then you would run that to the mobo. So basically no.
Edit: I have been proven wrong.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/264075-external-fan-controller/#findComment-3591696
That one is dual 5.25" bay.
I think you were looking for this one: http://www.nzxt.com/product/detail/79-sentry-lxe-fan-control.html
https://linustechtips.com/topic/264075-external-fan-controller/#findComment-3591709
That isn't want he is looking for, he wants one that can go on his desk.
https://linustechtips.com/topic/264075-external-fan-controller/#findComment-3591722
as far as i know. the nzxt lxe that was suggested above is the only dedicated off computer fan controller. aside from that you have the standard 5.25 bay controllers that you can set on your desk and just run extensions to depending on just how far away your computer is.
Blarg
https://linustechtips.com/topic/264075-external-fan-controller/#findComment-3592217
