PSU and GPU Help
Go to solution Solved by Luke,
Yup you'll be fine. I ran a R9 290 off that exact same PSU and the 290 apparently consumes more power than 270 crossfire - http://www.ocaholic.ch/modules/smartsection/item.php?itemid=1359&page=14
 Hi, I have a Sytem that is running off of 2 r9 270's with 2 gb of gddr5 each without any overclocking.
Yes, I know that 2 r9 270's in crossfireX is a weird choice, but I had reasons. Anyway, I have run
this through every psu calculator I know of, and since both cads only draw power from 1 6 pin pcie
connector, my 550 watt PSU should be perfectly suited to the task, with several watts of headroom.
But then I read a couple of things about unstable voltages off the PSU frying cards! I know I have the wattage
to handle both cards, but I was worried about the voltages.
     Can anyone tell me if my system will be stable at bare minimum? Thanks in advance, And
I will be upgrading the PSU ASAP anyway. Thank you, and here are the specs:
1 Asrock normal motherboard,
1 AMD A-86600k APU at 100 watt TDP
4x 2gb sticks of ddr3 1333,
1 seagate barracuda 7200RPM 1tb Hard drive,
2x r9 270's in crossfireX ( Powercolor turboduo model),
and the PSU is a SeaSonic S12ll-520 bronze. (it does have 2 6 pin headers.)
Once again Thanks for your help!
https://linustechtips.com/topic/263290-psu-and-gpu-help/
What the hell is an AsRock normal board, and can someone Photoshop this for me? I would, but I am working on something else.
As for the system, it should be fine. Your PSU is sufficient.
https://linustechtips.com/topic/263290-psu-and-gpu-help/#findComment-3581390
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
https://linustechtips.com/topic/263290-psu-and-gpu-help/#findComment-3581391
Really? I couldn't even run a 280 off a 550W. ThermalTake really must suck.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/263290-psu-and-gpu-help/#findComment-3581546
Thermaltake has so many different manufacturers that make their PSU's so it really depends on the specific model. Some are pretty decent while others are garbage - http://www.tomshardware.com/reviews/power-supply-psu-brands,3762-9.html
https://linustechtips.com/topic/263290-psu-and-gpu-help/#findComment-3581627
Yeah, I had a SMART 550W, couldn't handle my current system with any overclocks at all.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/263290-psu-and-gpu-help/#findComment-3582218
