I'm building this pc hopefully in time for Christmas to be able to play most games and be a bit future ready. This is my first time building one and i'm already stuck picking the parts, I wanted to go for 600 euros but i got to about 660 and still my cpu is kinda not great (I think the same goes for the motherboard). Is this the best i can do with this budget? The price on part picker is slightly different than the one i get on Italian Amazon which is where I'm probably buying most of these things. For Windows i get it from Dreamspark and I'm using a small 1920 x 1080 television as a monitor at least for now, hopefully I'll only use it as a second screen in the future. I probably missed some parts and I think that psu is kinda low wattage also I'm thinking in investing in a 750w one so in future i can get 2 x r9 280.
Any help in picking better parts in the same price range would be appreciated, also I'm not sure how to check if any of these parts are incompatible but i don't think they are. Thanks in advance
http://it.pcpartpicker.com/user/red25/saved/PKf2FT
https://linustechtips.com/topic/261937-help-with-my-first-build/
can you please set your text color to default ? us nigh themed persons can't see shit
https://linustechtips.com/topic/261937-help-with-my-first-build/#findComment-3566227
