a good ram for my biuld , i was going to buy 1866 cas 8 and then some1 told me to buy 2133 cas11 or cas 9 ,  the cas 9 is 1.6v and cas 11 is 1.5v
still cant decide which one to buy 1.6v is not stable right?
PCPartPicker part list: http://uk.pcpartpicker.com/p/2zDk8d
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£244.94 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£23.38 @ CCL Computers)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  (£84.99 @ Amazon UK)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  (£265.99 @ Amazon UK)
Case: Thermaltake Commander MS-I ID ATX Mid Tower Case  (£34.54 @ CCL Computers)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£56.34 @ Amazon UK)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  (£9.79 @ CCL Computers)
Total: £719.97
Generated by PCPartPicker 2014-11-30 20:35 GMT+0000
---Me Rig---
-CPU-
Intel i7 4790k
-GPU-
Gigabyte 970 g1
-STORAGE-
250gb ssd
Western Digital 1tb HDD
-RAM-
(2x4gb)
-PSU-
EVGA supernova 850w gold+
-MOBO-
ASUS z97-a
-CASE-
Some ATX Sized No-Brand
-PERIPHERALS-
Some Mouse and Keyboard.
https://linustechtips.com/topic/261086-ramm-problem-16v/
1.6V is perfectly stable
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/261086-ramm-problem-16v/#findComment-3557502
The Cas 9 is 1.6v because that's the voltage it needs to run at 2133 Cas 9, the Cas 11 is 1.5v because it has looser timings therefore it doesn't need as much voltage.
1.5-1.65v is more than fine for motherboards.
But this doesn't belong in "Graphics Cards."
https://linustechtips.com/topic/261086-ramm-problem-16v/#findComment-3557507
so whci to buy , 1866 cas 8   -  2133 cas 9    - 2133 cas 11
---Me Rig---
-CPU-
Intel i7 4790k
-GPU-
Gigabyte 970 g1
-STORAGE-
250gb ssd
-RAM-
(2x4gb)
-PSU-
-MOBO-
ASUS z97-a
-CASE-
-PERIPHERALS-
https://linustechtips.com/topic/261086-ramm-problem-16v/#findComment-3557538
Cas 9 2133 is better on paper:
DDR3-2133 CAS9 8.44ns
DDR3-1866 CAS8 8.6ns
It has a lower latency. So as long as the price differences between the two aren't too large, then go with the 2133 Cas 9 kit.
https://linustechtips.com/topic/261086-ramm-problem-16v/#findComment-3557548
thank you for your support,        1 last little tiny thing , does it matter if the ram is not listed in teh motherboard user guide , they have all other but not the gskill one.
and is there any other tip u can give , i ordered all my parts and going to build it in few days , like any other setting i need to change or something
---Me Rig---
-CPU-
Intel i7 4790k
-GPU-
Gigabyte 970 g1
-STORAGE-
250gb ssd
-RAM-
(2x4gb)
-PSU-
-MOBO-
ASUS z97-a
-CASE-
-PERIPHERALS-
https://linustechtips.com/topic/261086-ramm-problem-16v/#findComment-3557736
