Need help finding a mechanical keyboard.
I've spent a long time trying to find the right one but just can't.
It needs to have/be:
-Wired
-Wrist rest
-UK/Ireland layout
-FULL SIZE ENTER KEY. THAT'S SUPER IMPORTANT X_X
-Backlit (bonus points for customisability)
-Macro keys
-Cherry MX brown switches
-Full size (number pad included).
I don't really have a budget, but I obviously wouldn't want to pay tons.
Thanks.
| CPU: Intel i7 4790K @4.4Ghz  | GPU: Gigabyte GTX 970 G1 Gaming  | CPU COOLING: FRACTAL DESIGN S36 | MOBO: ASUS ROG Maximus Vii HERO | RAM: 16GB G.Skill Ripjaws X @1600MHz  | CASE: Phanteks Enthoo Pro Full Tower | PSU: EVGA SuperNova 850 G2 850W Fully Modular | HDD: 2TB Seagate Barracuda | SSD: 256GB Crucial MX100 | DISPLAY: Dell U2414H | HEADSET: Corsair H2100 Dolby 7.1 Surround |
https://linustechtips.com/topic/260802-need-help-finding-a-mechanical-keyboard/
Corsair K95 or Logitech G710+
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Neither have a full sized enter key x__x
http://www.overclockers.co.uk/showproduct.php?prodid=KB-031-CS
PSU Tier List | CoC
Corsair k95 RGB, just ordered mine :D
CPU: i7 8700k Motherboard: MSI Z370 Krait Gaming RAM: 4x 8GB Corsair Vengeance Pro (2 white, 2 black) GPU: MSI RTX 2070 Armor Case: Corsair Crystal 570x White HDD: 2x 2TB Seagate Barracuda 7200rpm Sata 3 SSD: 240GB Corsair Force 3 + 500GB Samsung 970 Evo Cooling: Corsair Hydro Series™ H150i PSU: Corsair RM750i OS: Windows 10 Pro 64-Bit
Mouse: Logitech G600 Keyboard: Corsair K95 RGB Cherry MX Brown Monitor: Samsung S24C570L 1080p 23.6" + AOC AGON 240Hz 1080p Sound: HyperX Cloud Headset Black/Red + Logitech Z213 Speakers 2.1
I wouldn't pay such a stark premium over the non RGB version just fro customization lights. Is there a non-RGB version with a large enter key?
Since you need macro keys, wrist rest, and brown switches. Your options will be very limited.
The only ones I can think of on top of my head would be the Corsair K95, along with the Logitech G710+.
Then you have two other keyboards from Razer and Logitech again which has MX Brown-esque switches.
All of these keyboards come at quite the premium, G710+ probably being the cheapest one of the lot.
Hi Ripull,I have some suggestions based on your desried keyboard but I don't really know what do you mean by ''full size enter key''. if you don't wanna pay tons for it, corsair k70 or tesoro durandal ultimate is pretty good. Currently im using Ducky Shine 3 but it doesnt have macro so Im nt going to put it in my suggestions otherwise it could be another great choice for you. :)
This is what I mean by full-sized enter key, lads:
Why do you need that enter key so freaking badly...? You'd open up your range exponentially if you just used a normal enter key.
I've used large enter keys for the last 14 years non-stop.
I've used both. The large enter key places less useful keys in an easier range for your fingers. I cannot find anything that fits your criteria because of that enter key. I'm pretty sure that's because you need special stabilizers for that style of Enter key.
See, I could probably get used to it, it's just that the enter key is so much like the backspace key that it makes me cringe.
I always thought the L shape enter keys were the most common types found on keyboards, but I very surprised now to find that is not the case.
