This is my motherboard Gigabyte GA-970A-DS3P Socket AM3+ 7.1 Channel Audio ATX Motherboard.
do i need to buy network card separate or does it have integrated. if i dont have to buy new one can someone tell me which driver i should install. my new pc wont connect to internet. wireless or with ethernet cable
https://linustechtips.com/topic/260441-do-i-need-network-card/
You need a network card for wireless
If you want to use a cable then you need to have installed the drivers first
Edit: Go to http://www.gigabyte.com/products/product-page.aspx?pid=4591#ov > Support & Downloads > Select OS > Realtek LAN Driver
Download and install
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/260441-do-i-need-network-card/#findComment-3550338
You'll have to buy a network card for wireless connectivity.
https://linustechtips.com/topic/260441-do-i-need-network-card/#findComment-3550343
If your ehternet isn't working, then download its driver from here: http://www.gigabyte.com/products/product-page.aspx?pid=4591#dl
https://linustechtips.com/topic/260441-do-i-need-network-card/#findComment-3550369
