This will be my first build and im wanting to make sure everything is compatible and will work.
pcpartpicker
I all ready have a mouse, keyboard, DVD-ROM and some monitors and a copy of windows.
This will be for gaming and possibly some 3D animation (Blender).
Just would like any advise before actually clicking the purchase button for this big order.
https://linustechtips.com/topic/259819-first-build-suggestion/
Why the 2400mhz ram? You can just use 1600 or 1833, not much of a performance difference but large price difference (also note the compatibility issue with the ram you chose) Also do you need the 730? There are some cheaper options like a Crucial MX100 that perform pretty well, but don't have the safety nets the Intel does for storage (but I don't see anywhere that you needed that). Also why two HDDs, you could pick up a 3TB for the same price.
Desktop: i7-4790k, Samsung 840 EVO 250GB, Seagate Barracuda 3TB, 2xR9 290 Vapor-X's (1 working atm), Asus Z97-Pro, NZXT H440 White, 16GB G. Skill Sniper RAM, NZXT HALE V90 850W.
Laptop: Samsung Chromebook 11.6"
Phone: 8GB Galaxy S4
https://linustechtips.com/topic/259819-first-build-suggestion/#findComment-3544419
2400mhz because its only $15-$5 increase. the 730 because its currently 56% off so its the same price. 2 HDD's for raid.
https://linustechtips.com/topic/259819-first-build-suggestion/#findComment-3544467
What res are you playing on first?
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/259819-first-build-suggestion/#findComment-3544471
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($299.00 @ Canada Computers)
CPU Cooler: Cooler Master Nepton 280L 122.5 CFM Liquid CPU Cooler  ($109.09 @ DirectCanada)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($174.95 @ Vuugo)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($124.99 @ Amazon Canada)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($119.98 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($79.98 @ DirectCanada)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($369.99 @ NCIX)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($59.99 @ NCIX)
Total: $1397.96
Generated by PCPartPicker 2014-11-28 20:11 EST-0500
A much better build for alot less... If you are gaming on 1080p.
840 evo has unbeaten reliability (i personally have it)... But i heard that intel SSDs have certain issues but im not sure.
Edited by xnoobftw
https://linustechtips.com/topic/259819-first-build-suggestion/#findComment-3544476
pcpartpicker
I would go with the Crucial MX100 SSD. It is a very good SSD and is cheaper than the Intel.
http://ca.pcpartpicker.com/part/crucial-internal-hard-drive-ct256mx100ssd1
Also the EVGA Supernova G2 is better than the Antec. The Antec is good, but like all Antec stuff it is pricey. The EVGA is $84.98 after rebate.
http://ca.pcpartpicker.com/part/evga-power-supply-220g20750xr
https://linustechtips.com/topic/259819-first-build-suggestion/#findComment-3544520
