So I found a really cheep 750 W 80+ bronze power supply that is "Factory Reconditioned" so what do you all think? Is this something you would trust in your build?
<p>CPU: AMD FX-8320 @ 4.0 GHz | GPU: Asus GTX 970 STRIX | RAM: 8GB (2x4GB) Corsair Vengeance LP 1600MHz | Motherboard: Gigabyte GA-970A-UD3P ATX | SSD: Samsung 840 EVO 500GB (Boot Drive) | HDD: 500GB | Case: Corsair SPEC-02 Red |PSU: Corsair 750W | OS: Windows 7 64-Bit | Mouse: Corsair M65 (Black) | Keyboard: Corsair K95 RGB (Black w/ Brown Switches)
https://linustechtips.com/topic/259730-refurbished-power-supply/
I bought a 430 watt corsair refurbished from newegg. Worked fine for me
https://linustechtips.com/topic/259730-refurbished-power-supply/#findComment-3543609
 what brand name ?
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/259730-refurbished-power-supply/#findComment-3543630
Depends. what PSU is it? Link?
https://linustechtips.com/topic/259730-refurbished-power-supply/#findComment-3543642
https://linustechtips.com/topic/259730-refurbished-power-supply/#findComment-3543683
https://linustechtips.com/topic/259730-refurbished-power-supply/#findComment-3543692
