Put in wrong standoffs for CPU cooler...
Go to solution Solved by Søren Bjerg,
Alright I managed to fix it - I found a screwdriver that fit the standoffs, now I just need new screws.
Now I can't get them out, they're stuck.
Does anyone know how I can fix this without buying a new mobo?
I'm sorry.. I feel bad but...
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs. And the Universe trying to produce bigger idiots.. The Universe is winning"
(Gaming PC) CPU:- i5 4690k 3.5GHZ . MOTHERBOARD:- MSI G45 Z97 Gaming . CPU Cooler:- H100i . GPU:- ASUS Geforce GTX-780ti Direct CU II OC -x2 SLI . RAM:- 16GB Corsair Vengeance 1600Mhz 4x4GB . CASE:- Corsair 750D Obsidian Series . PSU:- EVGA SuperNova 850W Gold . FANS:- x3 Corsair AF120 RED LED, x2 Corsair AF120 (Red rings) .STORAGE:- Kingston V300 120GB (Boot Drive), x2 1TB WD Blues, x2 500GB Samsungs .
KEYBOARD:- Logitech G19. | GAMEPAD:- Logitech G13. | HEADPHONES:- Logitech G35. | MOUSE:- CM Storm Sentinel Advanced II. | JOYSTICK:- Saitek ST200. | RACING WHEEL:- Logitech Driving Force GT. | OTHER:- TrackIR 5 + Vector Clip | CounterStrike XXL Mousemat
If they are plastic you could try cutting them with pliers.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
@FluffiestPond  lmfao so appropriate
 CPU: Intel i5-4690K  COOLER: XSPC Raystorm 750 EX240 w/ Ice Dragon White Nanofluid MOBO: MSI Z97 GAMING 5   RAM: G.Skill Sniper 8gb 2X4gb 2133   PSU: Corsair GS800  GPU: SLI MSI TWIN FROZR GTX 760 4GB CASE: Phanteks Enthoo Luxe    STORAGE: SAMSUNG 840 EVO 128GB, WD BLACK 1TB, WD GREEN 1TB, SEAGATE BARRACUDA 1TB, WD BLUE 320GB KEYBOARD: Ducky Zero DK2108S MOUSE: Logitech G600
I know, I feel so guilty, but I nearly spat my tea out reading it...
i blame lag :P
Do you reckon I could just get a screwdriver that fits the shape of the standoffs and fix it like that
To be fair anything is worth a try.. If you can't get them out you're .... *Puts on sunglasses* Screwed... OHHH YEAHHHHHHHHH
Make sure you have screwdrivers that fit the screws perfectly. One that is even just slightly smaller will require more force and might damage the screw more.
Normally, i'd say WD40 fixes everything. But i don't think it's a good idea to use it on a mobo.
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
Don't be afraid to use the hammer...I hammered out the stuck standoff one time and the motherboard surprisingly survived.  :ph34r:
i would NOT suggest this method
Product details would help, just grab some pliers and twist them out, just as you would if they were finger tight.
??? Pics. Getting lost here.
