So, I'm building a system for someone else.  I've got the motherboard in, the connectors plugged in, the power supply on, the ram in, the cpu in, the cpu cooler. And essentially everything done.
But... the system won't power on, the green light on the motherboard is on.   But, the fans won't spin, lights wont turn on.  NOTHING WORKS.  And its so frustrating!   Here are the specs:
Asus h97-plus
Stock cooler
i3 4160 cpu
corsair 330r case
cooler master v450s power supply
wd caviar blue 1TB
Please help would be greatly appreciated :'(   I'm getting more paperclips so I'll do the test on the power supply.
https://linustechtips.com/topic/258981-help-system-wont-boot/
Did you plug in the front panel switches and make sure they are on the correct pins? Power it on by the MB/hotswitch it with a screw driver or something
Asus h97-plus
Stock cooler
i3 4160 cpu
corsair 330r case
wd caviar blue 1TB
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/258981-help-system-wont-boot/#findComment-3537343
Asus h97-plus
Stock cooler
i3 4160 cpu
corsair 330r case
wd caviar blue 1TB
Hey Mike_The_B0ss,
I would follow @William12h's advice. Also try reseating all your parts and replug all the cables and make sure they are plugged in properly all the way. Also test your PSU if it's not faulty. Clearing the CMOS wouldn't hurt.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/258981-help-system-wont-boot/#findComment-3538928
  • 3 weeks later...
Hey Mike_The_B0ss,
Captain_WD.
Sorted it out. Motherboard was faulty, So I've got a new motherboard from gigabyte, works fine now.
https://linustechtips.com/topic/258981-help-system-wont-boot/#findComment-3702507
Sorry to hear that. I hope everything is fixed now and you won't have to deal with more problems. :)
Captain_WD.
https://linustechtips.com/topic/258981-help-system-wont-boot/#findComment-3703175
Captain_WD.
Yeah, poor guys who bought the parts.  They have to deal with this terrible customer service, mainly because the store keeps blaming me for it yet the motherboard was DOA.  I even told them with proof that a new motherboard with the same chipset (H97) worked just fine.
Thanks for your help anyways, and Thanks for your wishes.  I hope you have a great Christmas :)
https://linustechtips.com/topic/258981-help-system-wont-boot/#findComment-3703890
Likewise :) Merriest of holidays to you too!
https://linustechtips.com/topic/258981-help-system-wont-boot/#findComment-3704479
