Will a corsair ax860i 860 watt platinum power supply be able to provide enough power to sli gtx 780's, and a 4770k?
(I will be overclocking)
Intel 4770k   -   Corsair Vengeance Pro CL9 16gb 1866mhz   -   Corsair Air 540   -   Gentle Typhoon AP45   -   Corsair ax1200i   -   Razer Death Adder 2013   -   Filco Majestouch 2   -   Crucial m4 256gb ssd   -   1TB Western Digital Black   -   Asus Maximus vi Formula   -   Bitspower matte black fittings   -   Black Ice sr1 240mm and 360mm Radiators   -   Swiftech mcp655   -   EK x-res pump top   -   Promochill Advanced lrt 3/8 5/8 bloodshed red tubing   -   swiftech apogee hd cpu block   -   Asus pb278q 1440p monitor   -   Razer Carcharas Headphones   -   Razer Vespula Hard Mouse Pad   -   Arctic Silver 5 TIM   -   Sapphire r9-290x   -   Ek-fc R9-290x Waterblock and Backplate
https://linustechtips.com/topic/25853-is-this-enough-power/
I run a 3570k at 4.5 at 1.25 volts and two 7950s at 1200/1500 on a AX850 with no issues..I also have 8 HI PERF case fans 2 HDDs and a SSD and the nzxt hue led kit and a H100i..So as long as you don't have alot more then i have you should be fine..
https://linustechtips.com/topic/25853-is-this-enough-power/#findComment-328424
Yah that should be good. No water cooling right?
Yes there will be.
It is a full loop through both gpu, cpu and mobo.
https://linustechtips.com/topic/25853-is-this-enough-power/#findComment-328458
Yes there will be.
you should still be fine. Hope the rig turns out great ;)
https://linustechtips.com/topic/25853-is-this-enough-power/#findComment-328466
Thanks for the help guys!
https://linustechtips.com/topic/25853-is-this-enough-power/#findComment-328483
