Phanteks Enthoo pro
Solved by EarthboundHero,
well i have 3 fans and have really nothing to do with them so better them add to the case than throw away i guess.
And how do I place them? Which side should face down I mean, dont really know how to ask properly
The included 140MM in the rear exhausting, 200MM in the front intaking, two 120's in the top front and middle intaking and one 120 in the top rear exhausting.
