need help with my oced pc
Go to solution Solved by Samfisher,
^ FC4 specifically does not support dual core CPUs, same with Dragon Age Inquisition.
I  installed Far cry 4 on my editing rig it works fine but when I installed it on my lower budget gaming G3258 /R9 270 pc to run it doesn't even loads
is it the GPU bottlenecked or is it the CPU please help
Your in luck!
VvvvvvvvV
http://linustechtips.com/main/topic/257491-far-cry-4-actually-do-able-on-pentium-g3258/#entry3521067
