PC Build, CPU?
Go to solution Solved by Deletive,
It would not be better to go with AMD. if anything just upgrade to a i7 xeon (xeon with hyper threading eg. 1230v3) .
Hey guys,
Im building a PC on an AUD budget of 1600. I currently have a intel 15 4460 as my CPU but was wondering if it would be better to go with an AMD? I have a GTX 970 Graphics card and 8 gigs of ram. THis pc will be used for gaming, but also minimal video editing and photoshop.
------------------Hope This Helps------------------
                            Whirlpool
https://linustechtips.com/topic/257692-pc-build-cpu/
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523394
At this price point avoid AMD
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523395
I love AMD, but intel is your best option. I would get another 970 for sli then maybe a better intel processor and overclock it
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523396
It would not be better to go with AMD. if anything just upgrade to a i7 xeon.
Maybe not a Xeon
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523398
Amd CPUs aren't very strong. The 9590 is the strongest chip they got and the i7-4770k beats it.
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523399
AMD is dead in cpus. Long Live Intel. Fact: Intel has the next 20 years planned out.
"Instinct or Rationality; Which will you choose? Enchanted by a superiority complex"
"what you do in spite of internet speed is inspiring. :3" From Cae - 2015
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523429
Damn straight! B)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523436
OH MY GOD!! DID INTEL RELEASE THE I7-XEONS?! DO THEY RUN ON THE X199 CHIPSET?!
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523442
I think you meant an Intel i7 and an Intel Xeon CPU ;). There is no i7 Xeon. :P
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523449
I think you mean an Intel i7 and an Intel Xeon CPU  ;). There is no i7 Xeon.  :P
lol, I mean like LGA1150 Xeons with hyper threading :)
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523450
OH MY GOSH!! DID INTEL RELEASE THE I7-XEONS?! DO THEY RUN ON THE X199 CHIPSET?!
Yes they did and yes they do. They're amazing! Didn't you know?! :P
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523452
I love AMD, but for your budget Intel will be better than AMD.
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3523520
REALLY?! DO THEY HAVE 16 CORES WITH HYPERTHREADING @ 6 GHZ AND USE DDR5 RAM?!
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3528433
in single threaded stuff :P but ya i agree at the price point stay away from amd there beter for budget builds
Project black out: cpu: athlon x4 750k @4.7ghz, Mobo: asrock fm2+ a55 vg3+, ram: 1x 8gb hyperx 1866mhz, video card: 1x saphire radeon r9 270x, Storage: 1tb hdd ssd in the future,  cooling: 2 noctua 120mm fans 1 on rad one front intake.
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3528652
Absolutely! The CPU also has a max turbo boost of 20GHz. Quite an amazing CPU. The RAM, well, being DDR5, runs @ 7444MHz. Quite mind blowing...really! :P
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3528953
DOES THE MOBO, CPU, AND RAM COME FREE IF I BUY AN NVIDIA SHIELD TABLET?!
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3531192
You betcha! :P
I think we're having too much fun with this just quietly. :D
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3531411
You betcha! :P
This thread is pretty much dead now and we're just talking about something that doesn't exist, oh I'm sorry, it just came out tomorrow!
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3531527
This thread is pretty much dead now and we're just talking about something that doesn't exist.
Yeah, haha, damn straight! :D
Oh I'm sorry, it just came out tomorrow!
Now...that is kind of a confusing comment :huh:. You'd either say "It's just come out." or "Its coming out tomorrow". ;):D
https://linustechtips.com/topic/257692-pc-build-cpu/#findComment-3531883
