I'm looking for a decent & well built storage solution for a friend that has a budget of around $50 (I would assume the go to choice is a Hard Drive).
If anyone can suggest one that would be awesome.
Desktop: Intel 4770k - 12GB Vengeance Pro 1866Mhz RAM - Asus Maximus VI Formula Mobo - Asus Strix 970 SLI - Cooler Master V850 PSU -  Nzxt Phantom 630 Case  - 1TB WD HDD - Samsung 840 Evo 250GB SSD - Nzxt Kraken X60 - 24" Asus VG248QE 1080p Monitor - Logitech G35 Headset -  G502 Proteus Core - Logitech G710+ Keyboard - Nzxt Hue - Windows 10
https://linustechtips.com/topic/257468-looking-for-storage-replacement/
External or Internal??
If he wants internal just get this: http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex
or this: http://pcpartpicker.com/part/seagate-internal-hard-drive-st1000dm003
But if he wants an external drive then I would go with something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16822236605
My Current Build:
Intel i5 3570K @ 4.4GHz 1.11V, Cooler Master Hyper 212 EVO, Asrock Z77 Extreme4, Corsair Vengeance 8GB 1600MHz, Samsung 840 EVO 250GB, Asus GTX 760 DCII Overclocked, Corsair CX600M
I would get a Seagate 1TB hard drive for space, or a 1TB Seagate Backup Plus for external drives. Not really any good SSDs you can get for 50 bucks, but it's worth noting that Best Buy is selling the PNY Optima 120GB SSD for 48.99 on Black Friday.
Hi there @TheGosuStandard
Since your friend is looking for an internal HDD I would recommend the WD Green drive because it is designed for storage, quiet operational and has low power consumption. You can check it here if you want: http://goo.gl/B1tYPz
Hope this helps.
Cheers! :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
