Hello!!!
I have an asus p8z77-v deluxe and recently I deal with some problems.
Sometimes when I turn on my pc it displays an error code 00 and I have to push the reset button to start normaly.
Moreover, sometimes when I turn on my pc, immediately turns off and starts again.
What could be wrong?
Thanks!!!
Intel I9 7900X , Gigabyte X299 Aorus gaming 9, Gibabyte Geforce GTX 1070 8GB G1 Gaming ,G Skill ripjawsV 32GB 3200 MHZ, Samsung 850 Evo 500GB ,External WD 640GB, 2 x WD 1 TB Blue, Evga Supernova 750 G2, Logitech Z5500, Gigabyte Aivia Osmium, Logitech G502 Proteus Core, Corsair 750D Full Tower, Corsair H110, Asus VS248H 24", Asus VG245HE 24".
https://linustechtips.com/topic/256547-strange-problem/
Sounds like an unhappy psu, the pc is probably not getting enough power to get always going from try 1.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/256547-strange-problem/#findComment-3510620
Quoting: "The "00" code is a troublesome error to diagnose. On the surface, it might mean that the CPU is not detected but the error code can also be atributed to a motherboard malfunction or even RAM."
Just make sure all the cables are connected properly. Someone had this same code because he didnt plug un the 8pin connector,
quoting:"haha I am such an idiot! Hadn't connected the 8pin connector. But that's partly because of the confusion because of the labeling on the PSU. The PSU has two 8pin connectors next to each other and on the bottom, it says: 6+2 PCI-E & 4+4. It's the second one I should connect it to, right?"
Check that the CPU cooler isn't tied down too tight that it flexes the board as that can cause issues, try with one stick of ram at the time, check if all the connectors are in place. Check if cpu cooler's fans are connected
Specs:
PC:CASE: FD Define r6 | CPU:Intel Core i7-8700k | MB: MSI z370 PC Pro RAM: 32GB Corsair vengance LPX 3000 GPU: Asus rx 6900xt Tuf STORAGE: nand 500GB Samsung 970Evo plus ; Game Storage: 2TB Samsung 860QVO Storage: 2 x WD Green 4TB | PSU: Corsair RM850x | CPUCooler: Noctua NH-D15   DISPLAY: LG 27GL850
https://linustechtips.com/topic/256547-strange-problem/#findComment-3510628
He's got a 750W PSU, I doubt that s the issue with his setup. It should be more than enough
Specs:
https://linustechtips.com/topic/256547-strange-problem/#findComment-3510651
PSU's can degrade over the years or can be just faulty.
Motherboard can also be the problem, but it's weird it sometimes does work then.
Maybe reinstalling the cpu fixes it. Just taking it out and placing it back again.
https://linustechtips.com/topic/256547-strange-problem/#findComment-3510713
True, very true :)
Specs:
https://linustechtips.com/topic/256547-strange-problem/#findComment-3510790
I recently bought this psu.
I'm using a sleeve cable extension for the 8pin.
Maybe it is the problem.
With my previous psu I didn't have those issues.
https://linustechtips.com/topic/256547-strange-problem/#findComment-3510863
Are you overclocked?
I have the same motherboard and I've noticed that sometimes my computer will try to start up multiple times depending what overclock profile I have selected. For example I can boot up normally on my 4.2Ghz profile but sometimes my 4.4Ghz profile takes a few times to start up.
I can guarantee you though, it's not a power issue :)
CASE: Phanteks Enthoo Pro // CPU: Intel Core i5 2500K @4.2GHz // GPU: NVIDIA GeForce GTX 970 Reference // RAM: 16GB Crucial Ballistix Sport @1333MHz // MOBOASUS P8Z77-V LK // SPACE: 240GB Crucial M500 SSD ~ WD Black 1TB // PSU: Corsair CX750M //
CASE: Cooler Master Elite 130 // CPU: Intel Pentium G3258 @4.0GHz // GPU: N/A // RAM: 8GB Crucial Ballistix Sport @1600MHz // MOBOEVGA Z87 Stinger Mini-ITX // SPACE: OCZ ARC 100 120GB SSD ~ [2X WD Black 2TB in RAID 1] // PSU: EVGA 430W //
https://linustechtips.com/topic/256547-strange-problem/#findComment-3510974
I have my 3770k overclocked at 4.5ghz...I don't have any profiles.
I have put 1.28v,should I put more?
https://linustechtips.com/topic/256547-strange-problem/#findComment-3511181
Sorry for the late reply.
Anywho, 1.28v is what I have at 4.4, so maybe try a bit higher, like 1.3-1.35v.
I'm not sure if adjusting the voltage will fix anything though, but I would try it :)
https://linustechtips.com/topic/256547-strange-problem/#findComment-3511630
Guys, I found the problem. :)
The guilty was the 8 pin extension.
I had it from my the previous psu and I had to have removed it. :D
Probably it made some kind of short-circuit.
Thanks a lot!!!
https://linustechtips.com/topic/256547-strange-problem/#findComment-3515392
