I remember having a convo with someone on the forums here a while back, I've never done SLI, but I assumed that it was double the power...for example if you have two GTX 980s, I figured it would be 8GB and double all the other stats too. Someone told me that is not the case, how does it work?
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/256101-how-does-sli-work/
VRam does NOT add up, and they very rarely give you double the power in games. Most decently optimized games they give an ~80% performance gain over non-sli.
example benchmarks: http://www.anandtech.com/bench/product/1072?vs=1073
RIP in pepperonis m8s
https://linustechtips.com/topic/256101-how-does-sli-work/#findComment-3504604
Enjoy :)
Hmm ok. So what is microstuttering or frame time variance?
https://linustechtips.com/topic/256101-how-does-sli-work/#findComment-3504660
https://www.youtube.com/user/Techquickie
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/256101-how-does-sli-work/#findComment-3504787
Okay, in a perfect world, 60 fps means 1 frame every .017 seconds consistently.
In a micro-stutter situation, you still get 60 fps, but the frames are NOT consistently timed. Meaning, it could feel like the scene is jumpy and running at a lower fps...
Basically the frames could be clustered in groups and one frame takes like .04 seconds to draw on the monitor.
Micro stuttering means high fps, but not smooth.
Atom14 [Corsair] i5-4690K | Corsair H110i GT | MSI Z97S SLI Krait | 16 GB Team Group DDR3 | Samsung 850 EVO 250GB X2 | EVGA SuperNOVA 850W 80+ Gold | Corsair K95 RGB | Corsair M65 RGB | EVGA ACX 2.0 GTX 980Ti
Corsair KXX RGB Keyboard Cover Mod Make your own using my templates!
https://linustechtips.com/topic/256101-how-does-sli-work/#findComment-3504817
The SLI information guide in my signature (which for some reason never gets stickied) will tell you everything you need to know about SLI.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/256101-how-does-sli-work/#findComment-3504973
