Hey everyone, I have a strange problem with my new build I just put together, the power supply keeps "clicking" on and off when I turn my computer on.
It just goes: on, off, on, off, on, off. And it does this every 2-5 seconds until I unplug the power supply. My water cooler's LED remains on whilst it does this, however my GPU's led and my front fans flicker on / off with the power supply, however my back fan / water cooling fan remains off through out the whole thing.
Maybe this video I made will explain what's happening a bit better:
I've tried reseating all the cables and that hasn't helped, so idk what the problem could be.
Any help is appreciated!
Specs:
i7 4790k
gtx 970 gigabyte g1 gaming
corsair hx 750i
nzxt kraken x41
corsair air 540
Gigabyte z97x-ud3h-bk motherboard
https://linustechtips.com/topic/255875-strange-psu-issue/
If none of the ideas you get here work, RMA it.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/255875-strange-psu-issue/#findComment-3502382
What PSU is it? Sound like the OCP/SCP is getting tripped although it shouldn't restart by itself it either gets tripped
Edit: saw it was an HX 750i. Try unplugging it from everything then run it without any load. Short the green wire on the 24pin to any black wire to turn it on. See if still persists
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/255875-strange-psu-issue/#findComment-3502386
I've heard of an issue like this before. I think it had something to do with the motherboard stopping the power supply from damaging it or that the power supply isn't supplying the right amount of power to the motherboard and the components causing the on/off loop, The guy replaced the power supply and it didn't do it anymore. You should just RMA it and get a new one i don't think there is anyway round it.
love the title of the video btw.
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
https://linustechtips.com/topic/255875-strange-psu-issue/#findComment-3502420
when the psu restarts over and over again it usually detects a short circuit or some other fault during self check. Do you have any other psu available that you can try powering the motherboard on once just to see weather it does the same thing? Also try running with only the pare minimum of parts plugged in, so unplug everything and try using on board graphics unplug any harddrive any unneccessary fans and so on (unplugging the cpu cooler is a bad idea haha) and see weather is posts into bios. then you can detect any part that might be causing the problem
https://linustechtips.com/topic/255875-strange-psu-issue/#findComment-3502969
