Current setup:
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor
CPU Cooler: Corsair H60 74.4 CFM Liquid CPU Cooler
Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard
Memory: Kingston HyperX Blu 8GB (4 x 2GB) DDR3-1866
Storage: Seagate Barracuda 1TB 3.5" 7200RPM
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply
GPU: Radeon HD 7850 royalQueen CGAX-7852F 1024MB - GDDR5 - 256 BIT
Case: JCP KM6988 ATX
Monitor: PHILIPS 221EL2SB
Budget: Around 500 EUR, which is around 400 GBP. By this you probably must have figured that im not from the US, so yahh..
What i wanted with this upgrade, currently im using dual monitors, one is the one mentioned above, the other one is a small benq, not sure of the model LED monitor, which i would want to replace with another 21.5 inch monitor, preferably better than the current one. I was thinking about an SSD, but recently reading, with my rig, would it be necessary? Im free to suggestions.
https://linustechtips.com/topic/255854-a-small-upgrade/
