So in my build I am really leaning towards asthetics. However, the two front fans are not noticable. I am going to be using two corsair sp 120 mm mounted on top to a rad. And one corsair af 140mm mounted to the back. Im the front I am leaning toward two noctua nf-a14's. Let me know what you think. If you have any better suggestions let me know. Btw, I am not going to change the corsair fans :) They look too good.
Also in a corsair obsidian 750d
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/255550-fan-solution/
You defiantly want Static pressure fans in the front. My delta is at the top blowing air down to my motherboards VRMs
https://linustechtips.com/topic/255550-fan-solution/#findComment-3499199
Why sp fans in the front? I'm assuming because there is little gaps in the front of the 750d for air but I want to know why you say that
https://linustechtips.com/topic/255550-fan-solution/#findComment-3499445
Well there is the front plate then the fan filter then the case. Static pressure fans work great for restricted areas.
https://linustechtips.com/topic/255550-fan-solution/#findComment-3499501
