1. Get a silencer.
2. Get a night vision scope.
3. Don't try to attack any monsters unless you have to.
4. Stay in the shadows.
^^Pretty much, this also helps you save up ammo for the time when you can sneak about.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/255477-metro-ll-tips/#findComment-3498216
What? I though LL was easier than 2033 in terms of run and gunning?
Anyway just pay close attention to your watch. When your little "hidden" indicator is on you are literally like invisible as long as you don't make noise.
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/255477-metro-ll-tips/#findComment-3498243
