So I just got SickBeard 1/2 working, I'm using XSUSENET right now as my provider but for some reason right towards the end of the download it goes down to the History tab and says Download Failed - Out of your server's retention? So for instance I had a download at 550/593 MB and then it went down to the Failed History area, it does this for ever download towards the end of it and I have no clue why, can someone tell me if I have my settings wrong this is what I have for my provider settings on sabznzbd:
free.xsusenet.com
Port 119
Connections 2
Tetention time 10 Days
Timeout 30 seconds
No SSL
Not a backup server
and optional not checked.
Also, under General settings I have my download speed set at 1000 KB/s which should be equal to 1 Mbit, which is my limit. < Wrong, testing at the correct amount of KB/s down right now. Will reply back after I'm done testing
Any ideas, and if I need to switch providers I'm in the US and need a free provider. Thanks!
Gaming Rig - Excalibur - CPU: i5 6600k @ 4.1GHz, CPU Cooler: Hyper 212 Evo, Mobo: MSI Gaming M3 RAM: 16GB Corsair @2400MHz, GPU: EVGA 1060, Case: NZXT Phantom Full Tower (Red)
My Virtualization Server - Dell R710: 2x X5570s @ 2.93GHz with 32GB DDR3 RAM [Web Server, OSX, Plex, Reverse Proxy]
I love computers, gaming, coding, and photography! Be sure to quote me so I can respond to your post!
https://linustechtips.com/topic/255104-sabnzbd-help-please/
So I tried it with the changed download speed and then it got farther along to 593/593 but then went to failed... anyone have any ideas?
https://linustechtips.com/topic/255104-sabnzbd-help-please/#findComment-3494018
