Hey guys! Ok so I have to do this lab for my Intro to Computer Science class, but I don't understand it......like at all. It's partially because I was surfing the internet during class trying to find components for the computer I'm going to build. Yay! It's my first one so I'm pretty excited. Anyway, I was curious if someone could help me with the class in the lab that involves generating the random number. I know that there is a build in class in Java that generates random numbers for you, but I'm not really sure if that is what is necessary in this situation. I really appreciate your help! Oh and I can't quote people's replies because I use Internet Explorer (I know.....) so if you think that you could help me, I would appreciate if you guys would follow the post. Thanks again!!!!
post-162792-0-05872300-1416625519_thumb.
https://linustechtips.com/topic/255004-java-help/
I wasn't asking you guys to write the code for me, I was asking for some explanation of how to write it. I got help though so I don't know why you needed to post anything.
I'm not trying to be mean but this is kind of how your question read
"I have an assignment to do but don't know how to do it because I didn't pay attention in class. I haven't even tried to do anything so far but help me do this major component of the assignment. I know about this library that could help but because I haven't tried to use it, I don't know if it's what I need."
Showing your code can show us that you've actually tried and aren't just getting us to do your homework (people do that). It also gives us an idea of what you know and don't know. And we can see where the assignment is going right/wrong.
Anyway, if you have any issues while doing your assignment then feel free to post. I or someone else will help. However if the tutorials was all you needed to do it, then great. Good luck :)
https://linustechtips.com/topic/255004-java-help/#findComment-3493290
I don't understand what he means by an instance variable that generates random numbers. Wouldn't you just use a method for that? I don't really understand that.
Update: Oh wait...I think I figured it out! haha I'll repost later for you guys to check!
https://linustechtips.com/topic/255004-java-help/#findComment-3500557
http://linustechtips.com/main/topic/255169-java-question/?p=3496366
I posted on your other post.
1st: Make a method that is called in the constructor!
2nd: Pay eff'n attention in class, not everything is given to you, you need to earn most of it.
Much info
https://linustechtips.com/topic/255004-java-help/#findComment-3500606
There are many ways to tackle this.
One OOP way is to create a class called Die, which defines how many sides it has. It will define a Roll method, which in turn uses a Random number generator (this is delivered by the programming language) to return a result. Maybe even make a Roll overload which rolls the die N times and returns a collection of results.
Then you can make whatever small script or console app to take input from the user of how many dice they want to roll and how many sides each die should have. From the problem I see they use the XdY, where X is how many dice and Y is how many sides they have. You should be able to parse that pretty easily, just searching for the index of d in the input and naively treat everything before as a number and everthing after as a number. You could catch exceptions if the conversion from string to int goes wrong, and tell the user to fix that.
Don't worry about structure to begin with, don't overthink it. Just get started coding, this is a super simple app, not much can go wrong.
https://linustechtips.com/topic/255004-java-help/#findComment-3502655
