How to control fan speed with this cooler?
TallOne123
You can control the speed of any fan on your mobo doesn't matter how many pins it has.
You can do it in the bios all it means is that it doesn't have PWM Control
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
It appears to come with an adapter from the GPU 4 pin header to either a 4 pin molex for straight 12V or a 3 pin motherboard header for motherboard control. As it has been pointed out above you can plug this directly into your motherboard on a 3 or 4 pin header and use the motherboard to control the fan speeds through voltage regulation. Asus' AI Suite is great for setting a fan curve and you should be able to pick out the specific header (or at least a group of 3 pin headers).
"PSU brands are meaningless, look up the OEM."
