I recently build a Pc and got a BenQ Xl2420Z and a gtx980 G1 gaming. I am using a display port cable to connect them together. it boots up fine and all is fine until I turn off the monitor while the pc is still on. The monitor does not recognize the output from the gpu and I have to replug the cable to get the screen to appear.
Any suggestions why this happens?
https://linustechtips.com/topic/254284-dp-output-not-recognized-by-display/
this if i remember was a bug with the drivers i'll check hang on =)
Specs
CPU-Intel I7 4790K- @ 4.5Ghz / Mobo - Asus Maximus Hero VII / GPU - GTX 980 @ 1592MHz / RAM - 16Gb Corsair Vengeance Pro @ 2400Mhz / Cooler - Corsair H105 / SSD - Samsung 250gb 840 EVO / HDD - 2x 2tb Seagate/3x 3tb Seagate / PSU - Corsair RM1000 / Keyboard - Corsair K70 / Mouse - Corsair M65 / Case - Custom Glass panel Corsair Obsidian 750D -  Still saving for upgrades =)
Hmm... are latest drivers install for the card? Does the issue happen using DVI or HDMI?
"Rawr XD"
I would say install the display drivers and install the latest GPU drivers or reinstall them.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
read this article from NEC displays. It states the problem is due to some cable manufactures not adhering to DisplayPort wiring specifics.
Certain Mini DisplayPort to DisplayPort cables available in the market do not adhere to the
DisplayPort design wiring specification. This incorrect design causes power-related issues with
the display and/or host computer.
The DisplayPort specification states that a display (known as a "sink" device) must output power
on its DisplayPort input connector. The specification also states that a graphics adapter (known
as a "source" device) must also output power on its DisplayPort output connector. The idea for
providing power on both the "source" and "sink" devices is that certain other devices connected
between the two can receive power. Such devices may be, for example, a repeater or a converter
of some sort.
When a cable is used to connect a display directly to a graphics adapter, the DisplayPort
specification states that the cable must not connect the power line, and the power outputs of the
two devices should not be connected together via the cable.
The cables that were manufactured incorrectly connect the power line through the cable and
allow the power outputs of the display and graphics adapter to be connected together - a
condition that is forbidden in the DisplayPort specification.
Because the two power sources are connected together when using one of these cables,
situations can arise in which one device is actually supplying power to the other. For example, if
the host computer is powered off but the display is on (or even in standby mode), the display will
inadvertently supply power to the host computer, which may cause problems such as not being
able to power on, enter sleep modes or resume correctly. Similarly, if the host computer is
powered on but the display is off, the computer will be supplying power to the display, which may
cause problems with the display powering on.
Macintosh and Mac are registered trademarks of Apple
Here's the read>> http://www.necdisplay.com/documents/...ort_Notice.pdf
found this and see if you can change your monitor to detection always active
Specs
of some sort.
Yeah I got the GENERIC display port. Do you think that getting a new cable could fix the problem. I have the newest drivers etc
check your monitor for power saving, and turn it off, or look for a setting that has detection always active and turn it on , before buying a new cable
Specs
I just pluggied in a DVI-D cable and after I turned off the screen i went back on no problem
but display port is not the same as DVI - so if you want to use DVI thats fine, but it wont help you trouble shoot the DP connection
Specs
from what i understand yeah thats right
Specs
