so after some though i gave up on evo 212 (too big for my case :D )
so what 1st should i get ? case : Cooler master n300
                            or cpu cooler : Cooler master tx3 ?
i know that some cpu coolers are mostly airflow dependent. is tx3 the case (ta tum TSSSS) ?
i want to buy tx3 first beacuse its cheaper than the case. bit i want to know will i get any difference.
https://linustechtips.com/topic/254260-1st-case-or-cooler/
What case, cpu, and cooler do you have?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/254260-1st-case-or-cooler/#findComment-3483011
NZXT S340 case. Combine with a small AIO water cooler if you want to overclock. Throw in a tube of after market thermal paste.
Dubs are better than subs
https://linustechtips.com/topic/254260-1st-case-or-cooler/#findComment-3483210
