Hi guys, just got my new computer and started downloading some games like battlefield 4 and pay day 2 both download speeds seem to be capped around 7-6 mmegabytes per second. Using a plug which picks up WiFi and connects to my com
Via lan cable. Home plan is 300mbps. My old com also had speed capped around this , where do you think the bottlebottleneck is ?
https://linustechtips.com/topic/254124-download-speed/
Ok, so your home network is 300MB/s?! Dahm! Thought my 50 was high!
But i think it is the modem/router or network cable or wifi connector. Go to speedtest.net and test your speed there.
Also isn't 6~7MB/s enough?
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/254124-download-speed/#findComment-3481187
Mbit/s and Mbyte/s are different things.
100mbit/s is roughly 13mbyte/s.
So you could theoreticly have about 35mbyte/s
What category is the LAN cable? cat6, 5e or older?
I suspect the wifi is the bottleneck, Wifi is generally pretty bad.
What wifi card do you have?
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/254124-download-speed/#findComment-3481195
haha, don't live in the USA, well supposedly my friend could download it in 15min and that's 4 times faster than mine but he is directly linked to the lan port in his house.
https://linustechtips.com/topic/254124-download-speed/#findComment-3481207
Where do you live then? Tokio or something?
https://linustechtips.com/topic/254124-download-speed/#findComment-3481210
Singapore. SpeedTest.net told me 30mbps lol. Maybe it's the wireless connection
I think it is, yes. But it is also your distance from the server where you download it from. If you live right next to it you get higher speeds than when it is on the other side if the country.
https://linustechtips.com/topic/254124-download-speed/#findComment-3481233
You guys are forgetting something, that 300mbps is to the node thats the connection speed that doesnt mean that other people in the same neighbour hood are taxing the lines and slowing down the whole exchange.
i7 4790k | ASUS Z97 Gryphon | 8GB Corsair XMS3 1333Mhz | Asus Direct CUII GTX 770 1267/3829 | Stock Cooler | Antec Neo Eco 520W | WD Green 1TB
Silverstone TJ08-e | Klipsch Promedia 2.1 | Razer Tiamat 2.2 | LG 24EN43VS | Razer Naga (2010) | Razer Lycosa (2010)
Planned PC Upgrades: https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=325661&action=wish_lists
https://linustechtips.com/topic/254124-download-speed/#findComment-3481274
where is the bottleneck? The EA/Steam Servers.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/254124-download-speed/#findComment-3481406
