Only two 9 pin USB headers
Go to solution Solved by João Severino,
You could look into NZXT Internal USB Expansion Board
I believe it is perfect for what you need
Hello Guys,
Currently my Maximus V extreme only has two 9 pin USB headers. And I'm needing three. My case uses two alone.
Anyone know a adapter that can connect two 9 pin headers for the case into one connector.on the motherboard, so I can use the other connection for something else?
It's probably not possible but it's worth a try
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/25402-only-two-9-pin-usb-headers/
I dont think thats possible. But maybe buy a usb hub? or a pci one.
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
https://linustechtips.com/topic/25402-only-two-9-pin-usb-headers/#findComment-322035
Basically the case uses two and I need one for Corsair link.
It probably means I have to give up two on the front panel of the case.
https://linustechtips.com/topic/25402-only-two-9-pin-usb-headers/#findComment-322050
https://linustechtips.com/topic/25402-only-two-9-pin-usb-headers/#findComment-322064
Most PCI USB cards do come with an USB header on it. So you can expand yout I/O USB ports by an amount of X and your internal USB headers by 1 (mostly)
would look like this (this is for USB 3.0 though)
In the picture you see a Logilink USB Port expansion card.
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
https://linustechtips.com/topic/25402-only-two-9-pin-usb-headers/#findComment-322100
Who really uses more than two usb ports on the fp at the same time?
Just leave some of them disconnected..... Or actually. Don't even use corsair link. Who needs corsair link for what? You bios is so good on that board that you can set up a nice fan profile with the fans plugged into the mobo.
https://linustechtips.com/topic/25402-only-two-9-pin-usb-headers/#findComment-322140
That's exactly what I need it's perfect!
https://linustechtips.com/topic/25402-only-two-9-pin-usb-headers/#findComment-322145
Just need to find someone that supplies it in Australia
https://linustechtips.com/topic/25402-only-two-9-pin-usb-headers/#findComment-322170
