Frames Per Second Questions With Future Build
Solved by AlwaysFSX,
Google is your friend, instead of asking us right away put a little effort in to find your answer. You'd be surprised how easy it is.
http://www.bit-tech.net/hardware/graphics/2014/03/11/sapphire-radeon-r9-290x-tri-x-oc-review/7
http://www.maximumpc.com/sapphire_tri-x_radeon_r9_290x_review
http://www.eteknix.com/sapphire-r9-290-tri-x-4gb-graphics-card-review/
