hey,
i was serching for a storge solution
and i think nas will be a good thing for my
but i dont understand
1) when is start it,do i need to connect it to a monitor?it has any os?
Nas means Network attached storage you have to connect it with the ethernet cable to your modem or switch etc.
2)how can i interact with the nas?
You can map the network drive in my computer to access it. Some NAS have a web based GUI so you can access it through your browser.
thnx for helpers! :)
https://linustechtips.com/topic/25383-how-a-nas-works/#findComment-321788
hey,
thnx!
how can i connect my phone/tablet to my nas?
https://linustechtips.com/topic/25383-how-a-nas-works/#findComment-321794
thnx!
Depending on your phone/tablet, there are apps like ES File Explorer for Android that allow you to connect to networks and sort through files, play videos, etc.
https://linustechtips.com/topic/25383-how-a-nas-works/#findComment-321808
For connecting your phone/tablet to the nas as long as you have a nas that is dlna certified. I suggest the netgear Ready Nas Duo V2 and with that just dump files into the dlna share on it and then download the app called skifta and it should find the dlna streamer from the nas as long as it is on the same network. I use this on My Nexus 7 and it allows for me to be able to stream music and stuff like that over my network.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/25383-how-a-nas-works/#findComment-321809
