Need help choosing between generations :(
Solved by WoodenMarker,
So basically what I got from that was that a 3770k would be better?
What if I wasnt to overclock them at all? How would that change the opinion and what would be better?
If you weren't to overclock, you should go with the xeon which is basically a 3770 at $200.
Between 3770 and 4770, the 3770 is still a better bang for your buck. There's still a premium to be paid when going for haswell. Until the price lowers, I would recommend sticking with ivy.
