Student. Build.
Solved by Deletive,
I'm not being a ass about it, did you see me type shit? Obviously i acknowledge he has more knowledge than me, or else i would of been tripping out. The build is good, but the monitor is lacking which is why i prefer to go the AMD road, even if it doesn't have 8 fucking cores, I can get a better monitor for editing... So if you don't know the other side of the story then don't type some shit you don't know.
Then you should try this build if you want a better monitor.
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($174.99 @ NCIX US)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($74.78 @ Newegg)
Memory: Team Zeus Red 8GB (2 x 4GB) DDR3-1600 Memory ($64.99 @ Newegg)
Storage: Toshiba Product Series:DT01ACA 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ NCIX US)
Video Card: Sapphire Radeon R9 280X 3GB Tri-X Video Card ($199.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case ($64.99 @ Directron)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($32.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($90.26 @ OutletPC)
Monitor: HP 23xi 60Hz 23.0" Monitor ($149.99 @ Micro Center)
Total: $891.97
Generated by PCPartPicker 2014-11-19 00:12 EST-0500
