So I just realised...
I have a 500W PSU for a 350W (cca) system... Basically, I can put in a weak CPU cooler aaaaaand that's it!
That's not good. I am looking to buy a serious cooler, later on (but soon) and I need more wattage. Also, this system is quite future-proof and another GPU would need a lot more power. So I'm thinking... I should return this PSU, since I still haven't used it (hopefully I can) and get a better one (but it would need to be for a very similar price). I'm thinking somewhere from 600 to 700W... Can you please help me? I want a TRUSTED PSU. Modular/non-modular is not really a thing, since the price is already kinda fix. Cable management is also (I think) not going to be a problem, since the case is great (not that it really matters THAT much...).
https://linustechtips.com/topic/252989-not-enough-power-o/
If you're planning SLI, go for a 750w for a good amount of headroom.
Right now, you'd be fine, even with a good cooler and OCs on both the CPU and GPU.
I have 150W spare on this one and I went looking for some coolers and they seem to have high wattage. Is that true? I mean... basically it's just fans, right? That doesn't take much power... or does it? Can you recommend some coolers? What do you think, should I go thru the trouble of getting a new PSU or should I later on, (not so soon), when I get another 970, also get another, stronger, PSU? What do I then do with this one? Sell it on ebay for $50?
Legend:
not so soon - at least 6 months
quite soon - max cca 1.5 moths
Thank you for your help!
https://linustechtips.com/topic/252989-not-enough-power-o/#findComment-3466289
Legend:
What's your budget for the CPU cooler?
They don't take anywhere near 150W. The cooler itself (if it's a air cooler) takes no power, it's just the fans, and they don't use much power either. I'd go for a bigger PSU later when you get another card.
https://linustechtips.com/topic/252989-not-enough-power-o/#findComment-3466314
So basically any cooler should do fine?
I mean... water cooling is just some fans and a pump... right? How much does the pump take?
I haven't really decided on the budget for the cooler yet, but since I mostly do gaming and browsing, there is no BIG, URGENT NEED for overclocking, so something rather small would do - an air cooler that can get the CPU to somewhere like 4.0 gHZ, maybe 4.5 gHZ. (no idea on how it works for the temps and stuff)
https://linustechtips.com/topic/252989-not-enough-power-o/#findComment-3466346
Legend:
Most heat-generating components in a computer (CPU, GPU etc) will have a specification called TDP, which is measured in watts. This is a measure of how much heat the component typically outputs under moderate load. The wattage you will find on a CPU cooler's spec sheet is referring to the maximum TDP that it can effectively dissipate.This has no relationship to the power consumption of the cooler so you should be fine to use whatever cooler you want. CPU coolers generally use very little power, usually under 10 watts.
More on TDP here:
My PC:
4670k      GTX 760 ACX      CoolerMaster Hyper 412s      Fractal Design Node 804      G1 Sniper M5      Corsair RM 650      WD Red 1TB     Samsung 840 Evo 120GB
https://linustechtips.com/topic/252989-not-enough-power-o/#findComment-3466348
Most heat-generating components in a computer (CPU, GPU etc) will have a specification called TDP, which is measured in watts. This is a measure of how much heat the component typically outputs under moderate load. The wattage you will find on a CPU cooler's spec sheet is referring to the maximum TDP that it can effectively dissipate.This has no relationship to the power consumption of the cooler so you should be fine to use whatever cooler you want as generally, they use very little power, usually under 10 watts.
More on TDP here:
THANK YOU!
This has helped me a lot! I seemed to be confusing TDP and wattage required.
https://linustechtips.com/topic/252989-not-enough-power-o/#findComment-3466395
Legend:
If you get another 970 (not so soon) you shuld get a better PSU with that
i recommend (surprise) The EVGA SuperNova G2 750W
For the CPU cooler: get the BeQuiet! Dark Rock Pro 3 for performance and very quiet operation even on high rpms
Or the Noctua NH-D(14 or 15) which may cost a few bucks less, performs the same, is a tiny little bit louder and.... i personally like the DRP3 more for aestetics but thats personal taste here
Main Rig:
CPU: i7-2600k @4.8 GHz - CPU cooler: bequiet! Dark Rock Pro Motherboard: ASUS P8P67 Deluxe GPU: Gigabyte GTX 970 G1 Gaming SSD: Samsung 840 EVO 250GB - HDD: Western Digital Green 1tb - PSU: EVGA SuperNova G2 750W - Case: Fractal Design Arc Midi r2 -
Obsidian 250D Build Log
Wisdom: You don't live longer if you're always in a hurry
https://linustechtips.com/topic/252989-not-enough-power-o/#findComment-3466479
Well noise doesn't matter that much for me and my PC is "hidden" (translates to: in a place where no one look at it) so I think that if I go with air, I'll choose Noctua, but I am not there yet at all. Trust me, I will flood the forums when I am choosing a cooler...
https://linustechtips.com/topic/252989-not-enough-power-o/#findComment-3467175
