What is this pc for? Gaming, movies, Internet? What?
<p>CPU: AMD FX-8320 @ 4.0 GHz | GPU: Asus GTX 970 STRIX | RAM: 8GB (2x4GB) Corsair Vengeance LP 1600MHz | Motherboard: Gigabyte GA-970A-UD3P ATX | SSD: Samsung 840 EVO 500GB (Boot Drive) | HDD: 500GB | Case: Corsair SPEC-02 Red |PSU: Corsair 750W | OS: Windows 7 64-Bit | Mouse: Corsair M65 (Black) | Keyboard: Corsair K95 RGB (Black w/ Brown Switches)
https://linustechtips.com/topic/252470-first-pc-build/#findComment-3459321
Oh boy where to start.
Get a different power supply. EVGA G2 is an excellent choice.
Don't go with those hard drives. If you're going with 1tb, go with the WD Blue as it's $20 cheaper, or the WD Black. Why not go with a 2tb drive? WD Green would be my suggestion there.
You don't need the $9 wireless module. Your motherboard has built in wireless.
What's the purpose of the build? If it's gaming I'd suggest looking into a better video card.
Do you really need such an expensive optical drive? Seems really overkill.
I plan on using it to play simulators and general pc uses, word, internet and similar
What kind of sims?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/252470-first-pc-build/#findComment-3459338
its good.
would change the motherboard to Z97 since you need a bios update to use a z87 motherboard with haswell refresh
My PC
[ I5 4690k (no oc) - Gigabyte Z97 D3H - 8GB Ram - Sapphire R9 280X Vapor-X ]
https://linustechtips.com/topic/252470-first-pc-build/#findComment-3459340
Well if your not gaming then that will be fine. With what ^^^ they say.
https://linustechtips.com/topic/252470-first-pc-build/#findComment-3459341
Then its a grait pc if ur not going to eddit and the cpu is one of the best for gaming and ocing if ur planing to oc
Eddit: the card will need an upgrade
I didn't know what to put here...
https://linustechtips.com/topic/252470-first-pc-build/#findComment-3459363
i'll get the power supply and hard drive and what would you recommend for the video card and optical drive?
For the graphics card, I recommend anything after the 750ti. The 750ti is a really nice card for the money and everything after it pretty much kicks hiney
Definition of programmer: someone who can consume copious amounts of caffeine; and crap out a master piece through their fingers
https://linustechtips.com/topic/252470-first-pc-build/#findComment-3459403
try an get a 970 in ur $1000 build
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/252470-first-pc-build/#findComment-3459481
why such a weak GPU in a $1400 build. A 970 would be perfect for 1080p (ur mobo costs more than ur graphics card btw)
https://linustechtips.com/topic/252470-first-pc-build/#findComment-3459534
Haha. $230 mobo and  $150 GPU. Hilarious and totally not how you're supposed to do things.
You want a cheap mobo in the $130 region like the ASRock Extreme 4 or ASUS Z97A. Get yourself an R9 290 they're $250 in the USA now and it's a killer deal. Infinitely more powerful than the 750Ti.
Intel Inside. Overweight guy in his 30's outside.
https://linustechtips.com/topic/252470-first-pc-build/#findComment-3459612
