If you want a quiet build, then yes. You still have to do maintenance, just as air cooling has cleaning fans and heatsinks. Instead of replacing thermal compound, you flush out the loop and refill. Clean dust from radiators, etc.
If you plan on doing some overclocking, and are already throwing $1.5K into a machine, then I would definitely recommend water-cooling if you can squeeze out a bit of money.
317 is watching. 317 is everywhere. 317 is life.
https://linustechtips.com/topic/252444-water-cooling/#findComment-3459043
No. And yes.
I disagree completely. It's most definitely an ambitious task if you're new to building, but I would argue it's most definitely worth it. I'm currently running a machine overclocked to the wall that produces almost no noise and runs sub 70C. It's also got an incredibly pleasing aesthetic. The maintenance isn't crazy if you run clear coolant and blow out everything fairly regularly. Clean dust, top off loop and you're set.
CPU: i7-4770k @ 4.5GHz 1.2vCore     GPU: EVGA GTX 780 @ 1202/1762     RAM: Corsair Vengeance @ 2133MHz (11-11-11-27)     MOBO: Asus Z-87 PRO     PSU: Corsair AX860     SSD: 2x256GB Samsung 840 PRO     HDD: 1TB WD Black     CASE: Fractal Design Arc Midi R2
https://linustechtips.com/topic/252444-water-cooling/#findComment-3459110
