I am going to buy a pc with fx 6300 and r9 280x now i am afraid that this CPU will bottleneck this GPU so what so do you think
yes, but the difference will be about 5-10 fps, Austin Evans has a video on this topic (can't link it because i'm on my phone sorry, search for: is a high end cpu worth it). If you have the budget for it get a fx 8350 for some extra performance
-Edit, fixed some spelling errors
-Edit 2, here's the link: "Do You Need an Expensive CPU for Gaming?: http://youtu.be/qIT9uLDjZcg"
I5 4670k (Noctua NH U12S), Asus Maximus VI Hero, Nvidia GTX 560 ti Asus DCU II, 8GB Corsair Vengeance Pro, Kingston SSDNow v300 120 gb SSD 1TB Seagate Baracuda, Corsair Carbide 300R
I like pie
https://linustechtips.com/topic/252242-will-it-bottleneck/#findComment-3456558
Probably, but if I were you I would get a decent cooler and overclock the snot out of it, and then there would be only a little bottleneck. But if you can, just getting something like an 8350 would be better.
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/252242-will-it-bottleneck/#findComment-3456591
https://linustechtips.com/topic/252242-will-it-bottleneck/#findComment-3456947
Stop linking his video's please, they're horrible.
He tested a 3570K vs. 860K on a HD7770 iirc. He has no clue.
the video just shows bottlenecking on a low and a high end cpu
-Edit, I think austin is a great guy who knows what he is doing. also, why do you think he is clueless?
I like pie
https://linustechtips.com/topic/252242-will-it-bottleneck/#findComment-3457395
that video clearly tells you that you do need a good CPU to run these higher end graphics cards, just look at the results...
also austin is somewhat clueless indeed.
OP the 280X is no sloutch and if you want to get the most out of it defenetly consider a locked core i5 and cheap H97 motherboard instead.
The FX is fine with some games but might struggle in some others.(i know i owned one)
Why am i suggesting that? because in most cases an overclocking ready AMD kit will cost you more in the end than an i5 kit AND will not perform as well EVEN highly overclocked (again my FX-8320 was doing 4.6ghz and was still much slower at gaming than an i5)
Here the example, these are two typical choices both are basicaly as cheap as it gets or close to it, if you factor in the motherboard cost and the cpu cooler for the AMD overclocking it evens out the bills:
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($132.98 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Newegg)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  ($74.99 @ Newegg)
Total: $237.96
Generated by PCPartPicker 2014-11-17 10:10 EST-0500
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($69.98 @ SuperBiiz)
Total: $249.97
Generated by PCPartPicker 2014-11-17 10:11 EST-0500
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/252242-will-it-bottleneck/#findComment-3458002
